So my GPU fan is acting weird, not only is it spinning much slower than its counterpart, but also @ 50% + speed it starts to make a terrible hissing noise.
Any advice?
I made this video documenting the issue:
 Thanks!
"Hmmm, this is for sure the type of music you listen to,  if you want to lose friends."
'That last one' ??
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/
Any advice?
 Thanks!
If you can take the cooler off add some lubricant/oil to the fans as sometimes they can run dry and not run as well. This worked for me with my fan that made a ticking noise.
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/#findComment-8170891
Hmm alright, do you think sewing machine oil is a good lubricant, its about as thin an oil as I have access to
'That last one' ??
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/#findComment-8170903
Yea that should be fine and work quite well from my past experiences.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/#findComment-8170912
Okay, ill give it a go, it was pretty scary hearing that sound xD
'That last one' ??
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/#findComment-8170931
Yea, mine was at about 37% basically idle and it was a constant, tick, tick, tick and vibrations. Very annoying as i ran it at a higher speed to stop it but then the fans were way too loud.
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/633028-spooky-gpu-fan-dying/#findComment-8170945
