Hey guys need your help!!!
Solved by HKZeroFive,
Just now, Justin1196 said:ok thanks bro your a big help if i can get an evga that can replace the seasonic should i do it? and can a seasonic 500w PSU good?
There are some EVGA power supplies that are excellent and there are some which are bad. On the other hand, Seasonic generally makes quality power supplies so there are pretty much a safe choice regardless.
To answer your question, the Seasonic unit is fine. I'm betting it's unlikely you'll be able to pick up a good EVGA unit for the same price.
