So i overclocked my 6600k to 4.4Ghz and it runs just fine. I just have one question: in HWMonitor it says that my CPU is running at 4400Mhz, like it should. At all times. Can it running at full speed all the time affect its lifespan or any other thing? The temps are as expected, rising under load and being low when idle.
My mobo is a Gigabyte GA-Z170N-GAMING 5
https://linustechtips.com/topic/632779-overclocking-help/
No I run all my cpus at constant speed and voltage.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/632779-overclocking-help/#findComment-8167890
Well, any overclocks will reduce your cpu's life (Or any component in the matter) but the cpu will still last the whole build's life time or even longer (as long as the voltage isn't something insane).
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/632779-overclocking-help/#findComment-8167959
I've had mine on 4300 1.3v under Prime95 load for 29 days straight before I had to shutdown after it blew up on fire to paint my room. xD
Don't worry, you'll be fine if you can keep your temps in check.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/632779-overclocking-help/#findComment-8168149
