My ethernet adapter on my asus maximus vii formula randomly stopped working. I tried disabling and re-enabling, Uninstalling and restarting the computer, checked for driver updates, even disabled in bios and restarting. Nothing. Any ideas?
System
CPU
4790k
Motherboard
Asus maximus VII formula
RAM
16 GB corsair dominator platinum
GPU
EVGA gtx 980 reference
Case
Nzxt h440 black/red
Storage
240 GB rog raidr
PSU
Seasonic platinum 750w
Display(s)
Asus ROG swift pg278q and a Dell something free
Cooling
Corsair h100i
https://linustechtips.com/topic/632330-ethernet-adapter-failed-to-start-code-10/
is the mobo under warranty? try an ethernet pci card
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
5 minutes ago, Damocles said:
Did you try connecting with another device to rule out ISP or modem issues?
what?
it's a Windows device manager error (device cannot start), it has NOTHING to do with the cable/DLS modem or ISP ...
@Danelicious try the following instructions to see if it works;
https://support.microsoft.com/en-us/kb/943104
If you need help with your forum account, please use the Forum Support form !
Believe it's under warranty still but that's kinda a last resort. I'm going to pick up a nic today
System
CPU
4790k
Motherboard
RAM
GPU
Case
Nzxt h440 black/red
Storage
240 GB rog raidr
PSU
Display(s)
Cooling
Corsair h100i
Alright, one time i f**ked mine up and wouldn't connect like yours. Here's a fix and if it doesn't work you'll have to RMA the board. Go to device manager and uninstall the driver. Reboot the computer and windows will install the driver again. Then you update the driver and your adapter will reset to factory settings.
Blue screens eh? Did you try setting it to Wumbo?
I've tried exactly that. Didn't work unfortunately.
System
CPU
4790k
Motherboard
RAM
GPU
Case
Nzxt h440 black/red
Storage
240 GB rog raidr
PSU
Display(s)
Cooling
Corsair h100i
3 minutes ago, wkdpaul said:
what?
Sorry, I didn't read the code
if deleting the drivers didn't work then it's possible that the device is dead ... if the motherboard is still under warranty I would go for an RMA.
no problem, I've also misread things before !! xD
