Help!
Solved by Chewique,
Just now, Julian5 said:are you on windows 7?
Just now, Ichi said:I assume new rig?
If yes, did you get all the drivers installed?
Do not worry, i was a bit stupid and the cable wasn't quite in the plug properly and it needed jiggleing about a bit!
bill well ·
Posted in Peripherals0 -
3
2
Ha-Satan ·
Posted in Networking2 -
1
Beenlucky1 ·
Posted in Cooling3 -
Biermax ·
Posted in New Builds and Planning10 -
potatonut ·
Posted in Troubleshooting7 -
9
4
play_circle_filled
Latest From ShortCircuit:
