So i installed my new r9 270x recently and I have noticed in a few games that it says 60 or 50 fps but the game doesn't feel smooth at all. It's like i am playing something around 25 fps. I tried with Metal Gear Solid 5 and Evolve. In both games changing the settings doesn't affect performance at all. I checked my gpu while i was playing MGS 5 and i saw that my gpu was bouncing around in activity. Is my gpu broken or something ?
https://linustechtips.com/topic/632123-low-gpu-usage-low-performance/
What's your CPU ? Can you post your CPU usage during intensive games ? It feels like a CPU bottleneck
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
Just now, IHatePC said:
It's not the cpu. It has 80% usage at MAX.
80% is still quite high. Just to be sure, what's the model of the CPU ?
2 minutes ago, IHatePC said:
I'm sure it isn't the cpu but whatever: AMD Athlon 840 3.1Ghz (Boost Clock 3.8) 4 cores
What is your PSU? And driver?
PSU is 500Watts Cooler Master RS-500-PCAP-i3 and the driver is up to date.
use DDU and re-install 16.7.3
If that doesn't work try a different PSU
I get a similar problem when ill be play eso then suddently fps goes really low from 40 to 10, gpu usage drops but temps are fine and only way to fix is a system restart. I cant expect much from my old hardware but its annoying.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
Don't be so sure about that. In modern games that use quite a bit more CPU power, this processor is completely outdated and can bottleneck pretty much any recent GPU, even the low end...
Not that bad actually. 3.8GHZ Kaveri CPUs are okay. It's not an i5 but it's good enough for a 270X
It's not even an i3 or a decent FX processor. I can't see how this processor could handle modern games without major frame dips, even with a R9 270X. I've seen similar CPUs bottleneck GTX 570 and GTX 750Ti...
But I would also try to test a different PSU. Yours might be dying and struggling to deliver stable power.
I don't have frame dips. Are you even reading what i said ? i have stable 60 fps in every game. It just feels like 25 and my gpu usage is low.
Maybe you have a bad monitor or cables or maybe you eyes are amazing and see and much much faster fps than everyone else therefore 60fps looks laggy af
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Salty much ? What resolution are you playing ? What settings on MGS5 ? If you don't play 720p low settings, I can't see how you can get 60fps with low GPU usage on a 270x...
You may be right! About the monitor part. My monitor is 11 years old and im having huge cable problems. Everytimei move my cable even a little wierd lines appear on the screen and the pc reboots. I am getting a new cable today.
Salty ? I'm playing on max settings 720p go check a video if you don't believe me. And again the fps is not the problem here.
That sounds like a PSU and Monitor problem.
It's the same core found in the 860K and 880K and the 880K is just a 4.4GHz Kaveri CPU yet it matches the i3 4160 in terms of multi-core performance. With a 3.8 Boost clock it's better than what you see in Petniums and people are using those all the time
MGSV is incredibly easy to run. My 860M can run 1080p medium settings with ease. A 270X should have a much easier time
You should've started with that ! It's normal that you have low GPU usage at that resolution. Your 270x isn't stressed to the point of reaching 100% usage. With what you told before, it seems that you might need a new monitor and PSU...
