Hey, I am looking for a pwm fan controller for my NF-F12s.. i have look almost everywhere but cant find anything.. any help will be appreciated..
CPU: i7 4770k | GPU: Sapphire 290 Tri-X OC | RAM: Corsair Vengeance LP 2x8GB | MTB: GA-Z87X-UD5HCOOLER: Noctua NH-D14 | PSU: Corsair 760i | CASE: Corsair 550D | DISPLAY:  BenQ XL2420TE
Firestrike scores - Graphics: 10781 Physics: 9448 Combined: 4289
"Nvidia, Fuck you" - Linus Torvald
https://linustechtips.com/topic/63159-looking-for-pwm-fan-controller/
What's wrong with a straight voltage control?
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
If you want to control everything from a single PWM fan header, you can also consider a PWM splitter. Swiftech has one which I use to manage all my fans from the CPU header.
Not sure what PWM controllers are good though.
Desktop: Core i5-2500K, ASUS GTX 560, MSI Z68A GD65, CM HAF 912 Advanced, OCZ Vertex 4, WD 1TB Black, Seasonic P660, Samsung S27A850D, Audioengine A2, Noctua NH-D14, NB eLoops
Laptop: Lenovo Thinkpad X1 Carbon
Peripherals: Razer Blackwidow Ultimate 2013, Razer Deathadder 3.5G, Razer Deathadder 2013, Razer Goliathus Control, Razer Manticor
How many do you have?
3 NF-F12s (front intake x2 and cpu cooler)
2 NF-A15s (rear exhaust and cpu cooler)
I have pwm fans i would like to use them as pwm fans
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17923&cPath=73
One molex power, One PWM header, 4 controller fans :) Works a treat
I dont want to use the headers on my motherboard because the software for it is terrible and it keeps ramping up the RPM when evert the cpu goes under any load.. even if its just for a minute
Ah ok then. If you're looking for a normal PWM fan controller, I think NZXT/Lamptron/Zalman have some decent stuff. Not that familiar, so try to find a review or two before you buy.
If you're looking for something more high end, there's options like the mCubed T balancer and whatever Aqua Computer has(Aquaero 5 XT, etc). Those offer tons of customization, but may be trickier to use and are a waste of money if you don't need them.
You could use mobo headers and forget gigabytes own software. I use speedfan to cpu and open hwmonitor for other to keep them running at stable speeds.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
