Any i5 should do fine.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155106
Just now, Ichi said:
Your case in your sig gives me cancer.
Fix it!
I never actually noticed that lol
Blue Jay
Other Stuff
GitHub
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155117
Just now, Panda255 said:
Anything cheaper then a i5
Like I said don't cheap out on it.
Save up if you need to.
If it's not urgent then you can even wait for Zen and see what they have to offer.
My experience is I bought an i3-4150 rig because I'm in desperate need of a computer after my laptop dies out on me and I end up upgrading 2 months later to i5-4690k as I deemed i3 is not enough for my needs.
In the end I spend more money buying an i3 + mobo, selling them off for cheaper and buy another i5 + Z mobo.
You get the idea.
So now I would suggest just wait a little longer and save up if it's not urgent for you.
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155144
get a i7 with tht beast gpu come on...
i7 4790,zotac nvidia gtx 960,16 gb ddr 3 corsair vengeance,cm b600 v2,gigabyte h97md3h,2tb seagate+2tb wd,samsung 20",asus xonar dg + 5.1 creative,sennheiser hd202,cooler master elite 311,apc rs 1000g,logitech c270,xbox 360 controller for windows and d link wifi router..
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155145
1 minute ago, Panda255 said:
This is not helpful at all
get a i3 thenn
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155155
53 minutes ago, Panda255 said:
Hey im building a new pc with a gtx 1060/rx 480 and was wondering a good cpu and if you have any idea's of good cpus that wont bottle neck it and if you have more then 1 cpu in mind i wouldnt mind knowing
What is the budget for your entire computer? You seem to be disliking the fact that people are suggesting i5's since they are out of your price range. I agree with everyone here, if you want a good gaming experience, then save up until you can get an i5. However it might be entirely possible to get the i5 on your budget if you trim money away from other areas in your build.
For example;
An i3 6100 and GTX 1060 would be about this much money: http://pcpartpicker.com/list/vFzykT ($370)
an i5 6400 and RX 480 4GB would be about this much money: http://pcpartpicker.com/list/wvTWbj ($380)
The 1060 does beat out the 480 by a few fps in most games, but you can make up some of that difference by simply having a stronger CPU. and in CPU intensive games, having the much better CPU but slightly worse GPU would probably result in better overall fps anyway.
My recommendation is if you want to get the best gaming experience possible, you don't just need to throw more money at your computer, you just can try spending your money more wisely.
https://linustechtips.com/topic/631588-need-help-for-cpu/#findComment-8155224
