I'd like to measure/monitor the power consumption of a few devices (laptops, etc), any suggestions on energy meters or any other alternative methods/devices I could use? Thanks  :)
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
https://linustechtips.com/topic/63158-energy-meter/
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/63158-energy-meter/#findComment-863385
Yeah  :) I was wondering if anyone had any experience with such devices and hoped for some recommendations
https://linustechtips.com/topic/63158-energy-meter/#findComment-863396
Ah. I'm afraid I have no personal experience with this device, but the Amazon reviews seem to rate it highly.
https://linustechtips.com/topic/63158-energy-meter/#findComment-863484
Get a Kill A Watt. Has all the function you need for measuring real time Watts, kWh, and if you input the rates for your area, how much it cost you since the time you started measuring. Either one of the bottom most two devices from P3 will suffice.
Word of warning, make sure wherever you're plugging the meter into, you have sufficient clearance around it since the device does take up a bit of room.
Anyways, I do own one and use it to measure how much my rig draws when folding, gaming, benching, etc.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/63158-energy-meter/#findComment-863505
No problem, thanks :)
Awesome, thanks man!
https://linustechtips.com/topic/63158-energy-meter/#findComment-863570
