I've just got my new 1060 from Gigabyte today and installed it and then also installed the gigabyte xtreme gaming engine for OC and such.
I was planning for now just put it into OC-mode instead of gaming-mode but I when I press the OC-mode icon it does not light up as selected, is there a known problem here? I've search google for answers but can't mannage to find an answer for it.
The card is the D5 version and not the G1, Gigabyte says that this card has an OC-mode.
https://linustechtips.com/topic/630766-gigabyte-1060-oc-mode-problem/
  • 1 month later...
Hi, I just got the same card and have exactly the same problem.
I have contacted others too and they all the same issue so it isn't you or your specific card at fault.
In Gaming Mode it boosts up to ~1900Mhz anyway so it isn't a big deal for me.
But it would be nice to test it anyway :(
