My friend asked me for PC help with absolutely no PC experience. I have very little of it, but I tried constructing her with a build anyway and I wanted tips, with what I could introduce for this build for it to become better more efficient, stronger, or better price/performance. ( She also really wants to keep a red/black theme going throughout the PC with most of the components)
https://www.pccasegear.com/sc/yYR
if the link doesn't work, Refer to sc
Budget is around 1000AUD
https://linustechtips.com/topic/630697-first-pc-build-for-her/
dont go for an old AMD CPU at this point,
wait for the upcoming new bright shiny zen that hopefully bring back AMD on the CPU market
or get an intel i5 6500 (~190 bucks) or something like that
that'll give you a much better performance
also when the bugdet is  ~1 grand you should consider adding a nice SSD like Samsung 850 evo ( 250 gb or more )
even RAM would be nice 8-16GB or your system wont run
try pcpartpicker instead to select the items ;)
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/630697-first-pc-build-for-her/#findComment-8144520
Just now, 8-Bit Ninja said:
really solid gaming rig for under $1000
http://pcpartpicker.com/list/2zRjyf
looks great but are those BX SSD ok? only heard bad things about them low-end etc
https://linustechtips.com/topic/630697-first-pc-build-for-her/#findComment-8144552
10 minutes ago, Bl00dgod said:
dont go for an AMD CPU at this point, wait for zen or get an intel i5 6500 (~190 bucks) or something like that
Yeah the FX6300 was old when I bought mine in Jan 2014.
Also +1 on the SSD, and PCPartpicker
I edit my posts a lot.
https://linustechtips.com/topic/630697-first-pc-build-for-her/#findComment-8144562
5 minutes ago, Forward said:
omg, ty
Here: https://www.pccasegear.com/sc/x8M
$905 including your RAM
1x8GB ram so that you can have a possibility to upgrade to 16GB if you ever need to do so in the future. But if you feel that you don't need to upgrade then you can go for a 2x4GB kit  https://www.pccasegear.com/products/27405/kingston-hyperx-fury-hx318c10fwk2-8-8gb-2x4gb-white and utilize that dual channel
If you would like to have an SSD than you can swap out the harddrive for this SSD https://www.pccasegear.com/products/35326/crucial-bx200-240gb-ssd this would allow you to just simply add on a Harddrive in the near future without needing to reinstall windows.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/630697-first-pc-build-for-her/#findComment-8144606
Ty, I'll keep these in mind
https://linustechtips.com/topic/630697-first-pc-build-for-her/#findComment-8144616
