Hey guys! I'm having trouble picking between these 2 mouse-pads and I need to know which ones better and why (I play FPS games but I might play an another type of game every once in a while but I play all games mostly FPS though, not sure if that helps). Im using a laser mouse and I use a relatively high sensitivity. Out of 10 I would use a 7.5 Sensitivity. Ive listed 2 mouse-pads that you can vote for, The Steelseries Heavy, and the Steelseries 9HD, i've also made a option for Other which means another mousepad, if you choose other comment what mousepad it is.
Steam ID: StormC2
"Better to be hated, then to be loved for what your not"
:ph34r:
https://linustechtips.com/topic/63055-mousepad-help/
Using the SteelSeries QcK XL, and it is amazing.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/63055-mousepad-help/#findComment-861770
Go mice pads just go for something you like. Like design or size. Also hard mouse pad is better for FPS (twitch movement)because it has less friction. Soft mice pads can have difderent types of surfaces. Like smooth or more of a rough surface.
Quote me to get a reply!
https://linustechtips.com/topic/63055-mousepad-help/#findComment-861784
I've used both in the past for a short term, and they're both great. I'd pick QcK because I prefer the cloth surface and the portability. The Steelseries website says the 9HD is optimised for the Xai mouse, which uses a laser sensor, if that information is of any help.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/63055-mousepad-help/#findComment-861787
Used a steelseries Qck and the texture was horrible, rough and blarg.
If you live in the UK get a overclockers uk http://www.overclockers.co.uk/showproduct.php?prodid=GS-001-OP&groupid=702&catid=32
Soft and accurate, best pad I have used.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/63055-mousepad-help/#findComment-861789
