I have 3 monitors, 25UM56 in the center and 25UM58's on the sides. The 25UM56 is more blue and the sides are warm. Also I have a ColorMunki Smile. Is there a way to do color calibration in NVIDIA Surround? I tried to do it change the monitor's settings.
CPU: AMD Ryzan 7 7800X3D ECO Mode 105W & PBO Each Core -25 Mobo: ROG Strix B650E-F Gaming WiFi   RAM: 32 GB(2x16GB) G.Skill Flare X6 EXPO @6000MHz  GPU: ASRock Phantom Gaming OC Edition AMD Radeon RX 7900 XT
Case: Lian Li O11 Air Mini  PSU: Corsair RM1000e  SSD: Team Group MP34 4TB PCIe 4 NVME & 2x SSD 2.5 1TB, Mushkin REACTOR 960GB, Patriot Torch LE 960GB  Cooling: Thermalright Phantom Spirit 120 SE (PS120SE) with ARCTIC MX-6 & 9x Thermalright TL-C12 PRO 120mm
https://linustechtips.com/topic/630238-nvidia-surround-color-calibration/
You mean apply the same calibration to all monitors ?
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
No, to have each one calibrated to look the same.
