When I first installed my PSU, it was a really tight fit on the side panel due to so many redundant cables I jammed in there. It's pretty ugly.
My question is - can I cut away these unneded cables safely? I'm positive I won't be needing all these extra sata power connectors and what not.
https://linustechtips.com/topic/630111-cutting-unneeded-psu-cables/
Yes im 99% sure you can, but make sure you cover anything bare with insulation tape and make sure its nice and tidy
Yes you can do that.
But PSU will loose all of it's value, so you won't be even able to sell it as used or anything xD
I know that I would never buy PSU that got cables cut off.
But like Captain Shadow said, you need to cover those cables. Otherwise they might touch your case and kill you. Maybe not realy kill you, but you get the point.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
sell your PSU and get a modular PSU instead of cutting cables
so you dont void the warranty of your actual PSU by cutting anything and dont risk the health of you / your PC
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
Yeah that's true, don't really want to make it unsellable or void warranty. I'll think it out :P
Yeah they wouldn't kill you, but two of the wires could short out (which would kill the PSU, and possibly start a fire).
May Our Framerates Be High And Our Temperatures Be Low.
PSUs: EVGA B2/G2/GQ/GS, Corsair RMx/i, Grey-Label CXM, Everything Seasonic/Delta/Super Flower, XFX except XT
Use pcpartpicker.com
