So yesterday i bought new case NZXT Phantom 530 and Gigabyte GTX 970.
Me and my friend replacing all the components from my old PC to the new one. Here are the specs:
  1. i7 4790k
  2. Gigabyte GTX 970
  3. Corsair CX750M
  4. Corsair DDR3 Vengeance Pro 2x8(16GB)
  5. Gigabyte GA H97-Gaming-3
  6. Cooler Master HYPER 212X TURBO
When everything done, i plug the power cable behind the case, and turn the switch.
Funny thing is, before i press the power button in the top of case, my pc turn on for a split second, then turn off.
I tried the solutions from other forum like remove then insert the RAM stick, reseating heatsink, remove GPU. Still the same problem.
I bought the motherboard a year ago and PSU in 2014, so it's still kinda new i think. And have a zero problem before this.
Anyone knows how to fix it ?
you say it turns "on" for a second, so the fans spin or do you get a post or anything?
when only the fan(s) it could be because you turn the psu switch on and they get an impulse
if there is no burning smell of anything it might be only a plugg
you should try plugging all power connectors off and connect them properly ( 4pin + 24pin connectors maybe more depending on mobo )
maybe people will say its the CX thats gonna explode :D because many of them are supposed for "basic" non demanding builds
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
It's not a bug, it's a feature.
Wake on LAN.
Maybe some of your friends decided to change configuration on your PC + router and trolling you now to have higher bill :P
p.s.: I don't have any idea why that's happening to you.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
36 minutes ago, _chuck1z said:
Old or new storage?
Old
31 minutes ago, DaMainMan said:
Maybe something shorting out? I would try to reconnect/check everything -> Especially the power/reset headers.
29 minutes ago, MVPernula said:
My thoughts exactly.
Will try reconnect it all , thanks for the suggestion
28 minutes ago, Zyndo said:
Call a priest
Yes, PSU ,case fans are spinning. Case LED is on too for a second. And no burning smell
Will try to reconnect it all like DaMainMan said above
Wake on LAN.
Lol, dont think he could do that ?
Thanks for the fast response guys! Will update it later ?
15 hours ago, cipherism said:
Old
Well, disable wake on lan if you dont need it. Also, old storage hmm... Could be infected and is now a zombie for ddos attack. Idk for sure
I didn't know that feature until you mention it, lol.
I'm pretty sure i'm not enabling it.
Done recheck and reconnecting all the wires, still no luck :(
Could it be the motherboard ?
I post some pictures, hope it helps.
