3 minutes ago, AwesomeElite said:
Lets say i had a 750 watt psu from evga, would it constantly pull 750 watts from my wall or would it only pull as much as the components need?
all a PSU does is convert AC power from your wall to DC power needed to run your computer.
if your computer needs less DC power, the PSU will take less AC power.
it's important to note that PSUs are rated for how much DC power they can deliver, so a 750 Watt PSU running at maximum load would take more than 750 watts from the wall.
(if the PSU had 90% efficiency, it would draw 825 Watts from the wall running at maximum load)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
as much as needed
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
It takes as much power as PC needs + some extra based on efficiency. Let's say you have 85% efficiency and PSU needs 100W. It will actually take 15% extra from the wall, so 115W. But the power requirements fluctuate a lot as you are using your PC so the efficiency always change on different loads.
Basically... if you have any modern good quality PSU you are all set.
When you're ninja'd 13 hours too late by a newbie on the forum :P
