8 minutes ago, GeorgeKellow said:
You might aswell spend the same price on an air cooler for better performance
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/628588-good-aio-liquid-cooler/#findComment-8116896
9 minutes ago, CUDA_Cores said:
120mm radiators are stupid because more big single/dual-tower air-coolers match/outperform them. Get A noctua NH-D15, Phantecs TC14PE, Be quiet dark rock pro 3, something like that (The phantecs one I am currently using). Here are a couple I would get instead and will perform nearly the same or better for the same or less money:
http://www.newegg.com/global/uk/Product/Product.aspx?Item=9SIA68V21E0641
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835856002
http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835856004
UK links needed.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/628588-good-aio-liquid-cooler/#findComment-8117131
