Need a 2 pin extender
Go to solution Solved by WunderWuffle,
Bitfenix 2 Pin Extension.
EDIT: Go with the one that Matsy linked to.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/62822-need-a-2-pin-extender/#findComment-858349
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/62822-need-a-2-pin-extender/#findComment-858350
Wow 7$ compared to $2, go with what @Matsy said. I wouldn't worry about going with the cheaper one if you concerned about quality. It's 2 wires and 2 connectors Bitfenix just has a huge mark up on them
Hm. Didnt know that Modsmart has 2 pin extensions.
https://linustechtips.com/topic/62822-need-a-2-pin-extender/#findComment-858368
