4 minutes ago, Koujimaru said:
I am planning to buy either a 1070/1080. I have an i5 4670k OCed to 4.5Ghz.
Is it still good to go without performance issues or should I get a new CPU with the new GPU?
The CPU bottlenecking depends on what you're doing. A lot of games are inefficient AF these days and basically require an i7 to get the most out of them but if your games are truly optimized then the i5 is fine.
https://linustechtips.com/topic/628212-will-it-bottleneck/#findComment-8102237
your CPU is perfectly fine.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/628212-will-it-bottleneck/#findComment-8102246
CPU is fine for another generation or two.
Edit: Son's 4690 is still getting 100+ fps 1080 Ultra in most games with his 1070.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/628212-will-it-bottleneck/#findComment-8102270
It will bottleneck a 1080 at some degree. Only the Intel's skylake line i7 is capable of pushing most of the juice out of a gtx 1080, but even that will bottleneck a little bit in some demanding areas in some games.
Intel Core i7 6700K@4,3GHz - Asus Z170 Pro Gaming - Corsair Vengeance 16GB 2666MHz DDR4 - Evga SuperNova 750W PSU - Samsung EVO 500GB SSD - Gainward GTX 1080 GS - BenQ xl2411T 144hz - Cooler Master Haf-X Big Tower Nvidia Edition
https://linustechtips.com/topic/628212-will-it-bottleneck/#findComment-8108213
