hi
i will buy zotac  amp extreme gtx 1070
and new cooler for CPU and i plan to overclock my cpu to 4.3GHZ
and i was wondring is it enough power 750 ?
CPU : i5 4690k  (4.3Ghz)
M/B : ASRock z97 pro
GPU : gtx 1070 zotac amp extreme
HDD: 1TB black
SSD: 128 kingstone
Cooler for CPU : gtx corsair H100i
RAM: hyperX 2x4 kit
PSU : EVGA 750 bronze
Fans : 4 corsair 120M
thanks
https://linustechtips.com/topic/627923-750-power-enough/
4 minutes ago, secendFTW said:
hi
HDD: 1TB black
SSD: 128 kingstone
RAM: hyperX 2x4 kit
thanks
yeah
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099199
Yeah more than enough, but I'd recommend the gold series over bronze if you have the extra cash to splash :)
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099212
5 minutes ago, secendFTW said:
Thanks all :)
Depends on the model. If it's NEX B1 then it's crappy. If B2 then it's good. Also,
Expect serious bottlenecking
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099233
1 minute ago, secendFTW said:
i have B2 :)
what is the diffrent between gold and bronze ?
Efficiency. The B2 are solid units. Also, look into a 4790K if going for a 1070
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099251
7 minutes ago, secendFTW said:
i have B2 :)
To answer this and more (this is the minimum efficiency at about 20% usage or more):
  • 80PLUS: 80%
  • Bronze: 82%
  • Silver: 85%
  • Gold: 87%
  • Platinum: 90%
  • Titanium: 90% from 10%, 92% from 20% and on
Efficiency is slightly better with 230V mains power.
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099271
  • 80PLUS: 80%
  • Bronze: 82%
  • Silver: 85%
  • Gold: 87%
  • Platinum: 90%
:D
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099275
1 hour ago, AdamIsaacLang said:
The EVGA bronze are very cheaply made PSUs. Don't go for a high end build then cheap out on the PSU.
Get a Seasonic 650w 80+ Gold or a Silverstone strider 650w 80+ Gold.
The EVGA B2 is a very solid unit for the money. Cheaping out would be a Corsair VS.
https://linustechtips.com/topic/627923-750-power-enough/#findComment-8099475
