You can't really measure it with your eye, but I'd take the 3000MHz kit unless you are on X99.
https://linustechtips.com/topic/627376-cl-vs-clock-speed/#findComment-8093552
6 minutes ago, Andre01 said:
I am trying to choose between two different kits of DDR4 RAM (2x8GB). A 3000MHz CL15 and a 2400MHz CL12. I'm not sure which to get especially since benchmarks show very little differences between kits like this and the 3000MHz kit is cheaper (only by a bit).
I believe it depends on what you're doing. Like faster ram is better for editing if I recall.  But I would go with the CL12 ram as that has really low latency.
https://linustechtips.com/topic/627376-cl-vs-clock-speed/#findComment-8093558
A rough approximation of RAM performance is CAS divided by clock speed to calculate access time. Both sets of RAM are roughly equivalent, so take the one that is cheaper.
CPU: Ryzen 9 3900X | Cooler: Noctua NH-D15S | MB: Gigabyte X570 Aorus Elite | RAM: G.SKILL Ripjaws V 32GB 3600MHz | GPU: EVGA RTX 3080 FTW3 Ultra | Case: Fractal Design Define R6 Blackout | SSD1: Samsung 840 Pro 256GB | SSD2: Samsung 840 EVO 500GB | HDD1: Seagate Barracuda 2TB | HDD2: Seagate Barracuda 4TB | Monitors: Dell S2716DG + Asus MX259H  | Keyboard: Ducky Shine 5 (Cherry MX Brown) | PSU: Corsair RMx 850W
https://linustechtips.com/topic/627376-cl-vs-clock-speed/#findComment-8093610
