Setting default gateway in powershell
Go to solution Solved by Spev,
21 minutes ago, Spev said:
Anyone can help with this? Yes it needs to be done in powershell. I tried the Set-NetIPAddress but I don't see any kind of switch for setting the default gateway.
Have to use New-NetIPAddress and a switch is available. Not sure of the difference between set/new though.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/627217-setting-default-gateway-in-powershell/
