7 minutes ago, theworstjak said:
hay guyz i have a problem with crossfire i have 2x r9 380  i fell like its pretty low score how do i fix it and thanks
ALSO I HAVE crimson 16.7.2 the leastest one
You are likely being CPU bottlenecked. Watch your CPU utilization when doing the firestrike benchmark.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087645
Your graphic score is okay.
That's how much GTX 980 Ti gets at stock.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087736
Yeah but hes being CPU Bottlenecked and does not like the overall score...
5 minutes ago, theworstjak said:
hyper 212 evo
motherboard?
4 minutes ago, theworstjak said:
do i have to remove the other card and make it just one
No,keep both but try to overclock or upgrade
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087752
Well in that case OP should OC this CPU to 5,2GHz and let it burn xD
WD My Cloud 4TB
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087766
8 minutes ago, ivan_radeon said:
5.2 GHz
Total Wattage : 10000000000000000W
More like 250W xD
But when your CPU is using more power than GPU, you are doing something wrong lol
if i upgrade i would have to change my motherboared and cpu any idea on am3+ cuz idont want change
Don't upgrade AMD. From that CPU, there is no AMD to upgrade to.
The only upgrade I would recommend for you is i5 6600k. But you would need to buy new motehrboard + ram + cpu.
6 minutes ago, theworstjak said:
shit man i have 750 watt evga psu but it well be some much power draw
And warm room xD
WD My Cloud 4TB
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087807
5 minutes ago, Simon771 said:
More like 250W xD
And warm room xD
fuck that shit i going to get a gtx 110i v2
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087826
I would suggest you to get i5 6600k CPU if possible.
It will be worth it :)
WD My Cloud 4TB
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087838
Sell the CPU,RAM,Mobo and Cooler as a bundle and get a i5 6600k,the cheapest z170 board 8gb of ram for now and upgrade to 16gb of ram in the future and a better cooler than stock in the future
https://linustechtips.com/topic/626852-problem-with-crossfire/#findComment-8087948
