So, I'm planning on building a gaming rig that's powerful enough to new game titles (Like No Man's Sky, Battlefield 1, etc) on high (if not max) settings... I want things to look great and run smoothly. It'll also be used to do some coding but nothing to the point I should tailor my rig for (got one set up for all that stuff already) My issue is I'm more of a software geek so when it comes to hardware I'm a bit unsure. So I was wondering, what could you recommend for me to get. I'll post the parts I've been looking at buying, but if you think something else would be better, that's either cheaper but just as good, or better and not too much more expensive, more reliable or compatible (you get the idea) then please, let me know. Price isn't too much of an issue since I'm okay getting parts as I can, I don't really have a need to have it built ASAP. I'm really kinda unsure about where to start with this since I've not built a rig like this before and it feels a just little overwhelming so any help would absolutely amazing! :)
Parts I've been thinking about:
So for the GPU I've been thinking about getting a Nvidia GTX 1080, bit expensive but it seems like a damn good card.
CPU: AMD FX8350 8 core Black Edition
Not too sure yet, but probably 16gb of RAM
Motherboard... Well I don't really know what I should be looking for when it comes to a good board, other than something with a socket to match the CPU, and enough SATA ports... Other than that I'm really not too sure, so if you have any ideas/suggestion please, please let me know. I also can't really have a wired internet connectiong *Insert cry face* so I'll have to use WiFi, I've not had much luck when it comes to the USB adapters, so if you know of a WiFi card or something that goes on the mobo that'll be awesome.
I want at least 2 harddrives, I've been looking at a 1tb SSD, and the HDD I've currently got, which is small but it'll do for backing up data.
Case: I'm not set on getting a certain case, if you guys suggest a better one for any valid reason then I can change my mind, but for now I've been thinking of getting the Cooler Master MasterCase 5.
Powersupply. Now, where the PSU is concerned I'm really not too sure. I would like LED's lighting up my rig because if it's going to run beautifully then it might as well look the part too. LED lit fans too would be awesome (preferably purple)
Fans:... Well as I mentioned above, I'd love some fans lit up with LEDs, but I also want to make sure my rig has sufficient cooling because it would suck for it to overheat. I'm not really sure if there's better fans for what I'm going for over others, but I was just going to go for what ever fans I like the look of and would fit in my case (like I stated I'm more of a software person, not hardware)
I guess some additional stuff that could be useful to know is that I'm in England, so I would need parts that I can either get shipped here, or bought in store over here. Other than that, I hope I can get some help with this, and thank you in advance for any help :)
https://linustechtips.com/topic/625857-need-some-help-with-a-build/
If you want miniature sauna inside your case then go with 8350, otherwise i highly recommend intel cpu
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
budget location and what you plan on doing with it? for gaming what resolution
Edited by GDRRiley
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Get a Intel CPU, the fx 8350 is very old now and due for an update. Also use pcpartpicker, it's very time consuming and confusing to go over your long post.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
36 minutes ago, elBarto said:
http://pcpartpicker.com/list/8wtr6X
the 1080 is just for consuption measurement you can chose another one
The only thing I would change there would be the motherboard to OC-Formula and done! ready to go.
Really fun board if you have that kind of cooling and CPU. ;)
The AMD FX 8350 is very old compared to what? What's due for an update? Your comments are not clear.
Buzzsaw - I'm Buzzsaw and you're not.
CPU -- Intel Core i7 7740X @ 4.30GHz Kaby Lake 14nm Technology * RAM -- 16.0 GB Dual-Channel Unknown @ 1466MHz (15-16-16-35)
Motherboard -- ASUSTeK COMPUTER INC. TUF X299 MARK 2 (LGA 2066 R4) *
Graphics -- SAMSUNG (1920x1080@59Hz) -- 4096 MB ATI Radeon RX 560 Series
Storage -- 223 GB SanDisk Ultra II 240GB (SSD) -- 256 GB Crucial_CT275MX300SSD1 (SSD) -- 931 GB Western Digital WDC WD10EZEX-00BN5A0 (SATA) -- 2794 GB BUFFALO External HDD USB Device
Optical Drives -- ASUS DRW-24B1ST * Audio -- Realtek High Definition Audio
Here's my recommended computer build.
It's powered by an excellent AMD processor, which is very energy efficient and due to its low power draw, there is less heat generated.
I still added on a very nice CPU cooler.
A nice powerful 8 GB graphics card that can handle almost any game you throw at it plus it does virtual reality (VR) very well.
CPU: AMD FX-8320E 3.2GHz 8-Core Processor  (£109.00 @ Amazon UK)
CPU Cooler: Cooler Master Vortex Plus 54.8 CFM Sleeve Bearing CPU Cooler  (£39.92 @ Amazon UK)
Motherboard: Gigabyte GA-990FXA-UD3 R5 ATX AM3+ Motherboard  (£125.11 @ CCL Computers)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  (£84.36 @ Amazon UK)
Storage: Transcend SSD370 128GB 2.5" Solid State Drive  (£44.63 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£39.59 @ BT Shop)
Video Card: Sapphire Radeon RX 480 8GB Video Card  (£219.99 @ Ebuyer)
Case: Corsair SPEC-02 ATX Mid Tower Case  (£51.99 @ Amazon UK)
Power Supply: SeaSonic EVO Edition 750W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£89.02 @ CCL Computers)
Total: £803.61
Generated by PCPartPicker 2016-07-13 20:09 BST+0100
Basically everything intel, we had ivy bridge, haswell, broadwell, skylake.... AMD still is in the 32nm process with the same piledriver architecture for their FX series since 4 years now.
Quote
Vishera as a whole including the 8350 he is considering, Zen is coming late this year.
While it's comparatively more efficient, it still has a higher TDP than a i5 6500/6400 and is in an older platform that doesn't offer many upgrade options (your best bet is a 8350, which isn't much faster and still slower than the i5:
https://linustechtips.com/main/topic/401217-amd-fx-vs-intel-for-gaming-2015-edition/).
Would rather get a i5 6400/6500 with the stock cooler. You can later upgrade to kaby lake, is more powerful (even with overclocked benchmarks: https://www.youtube.com/watch?v=CssrJh315DQ ) and is more efficient at 65 TDP.
