I am building a new PC and due to the deals on Amazon today I just had to pick up an Ultrawide monitor on sale. I got the LG 34UM68-P for $350 so it was a pretty good deal. My build is http://pcpartpicker.com/list/QdK29W and my main question is did I make a good choice with the monitor? I was going to buy a normal 27" 1440p display but just had to try the Ultrawide. I plan on buying a GTX 1070 so I won't be able to use the free sync but should still be able to use the full 75hz right? Please tell me if I made a good choice or not! Haha
https://linustechtips.com/topic/625460-going-to-ultrawide/
yeah you should be able to still use 75hz for it
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/625460-going-to-ultrawide/#findComment-8072415
I bought the same monitor during the sale aswell. I'll be getting it tommorow along with ano rx 480. I plan to usensure this setup until I get a 1440p ultrawide and I'll get another 480 for crossfire. From all the reviews I've seen its been nothing but praise. The only downside being that it's 1080p. If your used to 1080 at about 28 inches like I am than you won't notice the resolution.
https://linustechtips.com/topic/625460-going-to-ultrawide/#findComment-8079402
