Hey guys, I gave a Asus ROG GL552VW, which comes with a M.2 slot. I just installed my adata 128 GB SSD and im having alot of trouble with it. the drive shows up in my bios, but for some reason when i try to set it up in disk manager it shows this error message and oddly the size is wrong as well. Mircosoft support was useless as usual and Asus wasnt much help as well. Anyone on here can give me some advice on how to fix this???Screenshot (20).png
Current built PCs:
1: XFX DD  AMD R7 260x / AMD FX-6300 4.7ghz OC /  MSI 970A Krait edition mobo / Deepcool captain 120 AIO cooler / 10gb of 1866 ram???? / 750W evga psu  / 1TB Seagate 'Cuda + 16GB SSD /  packed into a Bitfenix Shadow  window
2: Intel G3258 3.5 GHZ OC / G1 gaming 4gb GTX960 / 8GB of Ram / 128GB A-data ssd/ misc gigabyte mobo / Alpine Pro rev2.0 cooler / 500W Seasonic PSU / in a Bitfenix Pandora Window
3: AMD A6-7400K 3.8 GHZ OC / Misc AM2+ Gigabyte mobo / Cooler master Hyper T2 Cooler / 1 TB Seagate 'Cuda / 8GB 1866 corsair vengeance pro RAM / XFX 500W psu / in a cougar spike case
4: Intel G3258 oc 4ghz / Random MSI mobo / 1TB seagate 'Cuda / Cooler master hyper T-4 / 8GB Fury X ram / 4GB Club 3D R9 380 / 500W EVGA psu / locked up in a thermaltake versa N21 window
5: AMD FX-6300 4.1OC / Cooler master T4 cooler / MSI 970A gaming motherboard / 1TB Western digital blue / 8GB Hyper X Ram / 500W Thermaltake PSU / 2GB XFX DD R9 280 / Bitfenix Nova window case
The odd laptop: Asus ROG GL552-VW / intel i7 skylake / GTX 960M 2GB / 1TB toshiba HDD / 128 GB A-data M.2 SSD
https://linustechtips.com/topic/624688-help-m2-ssd-issue/
I'm not overly familiar with these things, especially if its an NVME drive, but usually when you plug an m.2 drive, its not directly plug and play. you often need to go into your bios (even though its recognized) and tell it to run in a certain way. M.2 bus often shares bandwidth with other things like a PCIE port or SATA express, so be sure to check your laptop manual and ensure that you don't have anything else plugged into the shared areas. If you have already done these steps, then I'm at a loss.
I'm sorry I couldn't be more help than that. I don't really know enough about these things to give you a specific answer.
https://linustechtips.com/topic/624688-help-m2-ssd-issue/#findComment-8063295
Thats really strange. my laptop came with a HDD, Im really not sure what settings to tweek around with in this laptop. Thanks for your help Zyndo, but im still really not sure what to do :(
Current built PCs:
https://linustechtips.com/topic/624688-help-m2-ssd-issue/#findComment-8063376
Googled the error message and this is the first thing that popped up: http://www.wikihow.com/Fix-a-Cyclic-Redundancy-Check-Error
Hopefully that resolves it, I've never seen that error before.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/624688-help-m2-ssd-issue/#findComment-8063394
hey! thanks for your help, i tired all of that, like check disk in command promt, but the disk isnt even detected as of right now.
Current built PCs:
https://linustechtips.com/topic/624688-help-m2-ssd-issue/#findComment-8063412
