 Playing BF4.
 No irregularities, 60+fps
 Close game
 Chrome is only thing open
 Pc just shuts down as if I turned the switch off at the wall
Turn PC back on, goes to motherboard menu (press key for bios)
A tonne of text in polish that translates roughly to windows error something, launch normally or run diagnostics?
Both options lead back to the motherboard screen.
Whole thing loops over and over.
Specs:
Amd Fx 8350
Gtx 970 (standard) / Gtx 660ti (Spare one that I tried with no difference)
12Gb Ram
Asus M5A78L-M motherboard
Windows 7
Any help?
Tried:
Clearing Cmos
Changing GPU
Checked cables
Changed battery
Reset Bios
https://linustechtips.com/topic/624686-boot-loop-help/
You try clearing the cmos?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063234
Restoring BIOS defaults?
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063253
5 minutes ago, laptopgeek said:
Done it.
Minor issue, random squares are popping up. I'll post a picture in a minute
random squares popping up does not sound like a minor issue.
Such things can hint to a graphics card failure.
That could explain the bootloop.
Do you know your GPU's temperature during average gaming?
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063301
Never goes higher than 50. Also, I tried my old 660, with no difference
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063319
2 minutes ago, laptopgeek said:
Slightly larger issue now, It's become lines.........
I would say gpu but i realised you checked your other one, maybe ram?
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063323
You've tried a different graphics card, and still lines and stuff?
This is what my screen looked like when my HD6570 burnt out.
Tried a different cable and connector?
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063334
The p
It's not the cable, I tried it on another PC and it worked fine. Also, the lines aren't all the time. They've only appeared on the black screen with the flashing cursor.
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063361
No difference, swapped 2x 6gb for 1x 4gb. Stuck on the flashing cursor from before, but no lines yet. Although they'd probably show up if I waited a bit longer.
I would guess from the shear process of elimination that it is your cpu or mobo, what were the cpu temps while gaming?, were you overclocked?
My Setup :P
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063429
Never mind, 2 secs after posting, this came upWIN_20160711_20_49_45_Pro.jpgHard to see, but jut random dots
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063438
Not sure about cpu temps, and it was overclocked slightly. Not to mention that there's a tonne of dust in there, which is probably the cause
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063451
Is this your board? https://www.asus.com/uk/Motherboards/M5A78LMUSB3/
If so it is a 760 chipset with the vrms having no cooling so maybe it is something to do with the board?
Im not too sure being honest
My Setup :P
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063478
Yeah, that's the board
Im not sure but i would look towards the board (not saying that is the problem, it would be my guess though)
My Setup :P
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063528
A very easy one, is take another motherboard, and connect all your other hardware (psu, gpu etc) to that mobo.
If the problem still occurs, either the mobo or the CPU is to blame.
My guess goes to the mobo.
https://linustechtips.com/topic/624686-boot-loop-help/#findComment-8063669
