Hey, guys, I know it might seem dumb, but my computer just isn't performing how I feel it should be. As of right now, I'm using the combo of an I3 4170, and a (Non-X)R9 270. I don't know if it's the CPU, or the GPU, or both, but this computer struggles to do some of the most basic things. From just playing Insurgency with Frame Drops everywhere, Having to play overwatch on Low just to make it playable, terrible stuttering in almost every game I play, and even my browser (doesn't matter which browser I use, they all crash in this instance) just flat out giving up when scrolling through Facebook. I was thinking, maybe just buy a RX 480, and boom, problem solved, but I wanted to know if maybe there could be other factors that would be slowing down my PC. It's kind of been like this ever since I first got it, so I don't feel like it's something to do with having Malware/Viruses, because I usually have my Anti-Virus off in the background, but when I run scans it says my PC is fine. Any suggestions? Thanks.
https://linustechtips.com/topic/624053-not-up-to-par/
grab a SSD and reinstall windows on it. also make sure you get all of your drivers.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/624053-not-up-to-par/#findComment-8052567
I don't see how grabbing an SSD would prevent almost any of the issues stated. Also, I'm fairly certain all of my drivers are up to date.
https://linustechtips.com/topic/624053-not-up-to-par/#findComment-8052606
update your drives then
https://linustechtips.com/topic/624053-not-up-to-par/#findComment-8052650
