Hard drive for recording! HELP
Then in that case I would go with a Seagate Barracuda. They're cheaper than WD Blacks but perform the same. The only difference is the warranty which is 3 vs 5 in favour of the black. Ideally you would want an SSD as that would give you better frame rates in game however if you're cash strapped, a decent hard drive will suffice. There is little point in using an SSD cache or hybrid drive.
Featured Topics
DoughmanX_HD ·
Posted in Windows1 -
220VoltsallCore ·
Posted in Operating Systems2 -
Ridoheru ·
Posted in Graphics Cards0 -
EpicAAron ·
Posted in General Discussion0 -
3
Alexis-Ms_Sun21 ·
Posted in Troubleshooting0 -
2
Cramig88 ·
Posted in New Builds and Planning14 -
Ghostsanonymous ·
Posted in Displays3
