Too much right?!?
Go to solution Solved by Energycore,
Eh, don't cancel the order on the GQ. It's a good power supply and good power supplies don't go for less than $50
I have ordered for my friend a psu EVGA 650W GQ but its not yet delivered but i think that is to much for that new build (Msi 170A Pro Gaming, i5 6600k (maybe will be a little overclock after) , will be buying a RX 480 (waiting for a better design like the sapphire nitro edition) , Kingston 2x8GB 2400MHz and a WD caviar blue 1TB maybe and SSD.
Do you recommend me going to 600W or 550W? and something cheaper? or its ok the 650 if i overclock?
https://linustechtips.com/topic/623450-too-much-right/
THere is no such thing as "Too much wattage" since it's just a limit, not a recommendation of what kind of power draw you should have.
650W is most definitely enough to power that entire system even with an overclock on both the CPU and the GPU pushed to the absolute limit. Try maybe the new CX550M psu from corsair (Check for grey sticker, not green) or the seasonic S12ii 520W
Remember to quote if you want us to see your answer ASAP!
https://linustechtips.com/topic/623450-too-much-right/#findComment-8037389
That just means that when you're gaming you'll be sitting more or less in the sweet spot of that PSU's efficiency curve, so I wouldn't worry about it too much.
A good PSU lasts years and years and years, too, so if you buy overkill right off the bat, then you won't need to upgrade if you decide to do something quite stupid in the future (like I don't know Crossfire RX 690s?)
https://linustechtips.com/topic/623450-too-much-right/#findComment-8037412
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/623450-too-much-right/#findComment-8037417
Keep your GQ. It will simply be more silent due to you running at the peak of the efficiency curve
https://linustechtips.com/topic/623450-too-much-right/#findComment-8037485
Keep the GQ.
https://linustechtips.com/topic/623450-too-much-right/#findComment-8038889
