ram Hard system freeze and Memtest86 error with XMP on
I've experienced multiple compatibility problems with higher speed ram (typically 3000+) and different mobos. If you turn XMP off, it'll run at whatever the SPD lets it, typically 2133 or 2400. This is fine and safe, but you're not getting the full performance of the ram you paid for.
I found that newer bios releases for mobo can help, so make sure you're up to date. Advanced uses might involve tweaking voltages but I'm not really experienced enough to guide further. In the end I just got different ram which happened to work better. Lucky dip.
Note I first had this problem on my main rig (Maximus VIII Hero), which started with G.skill Ripjaws 4 3333. Early on I had perhaps one detectable error per week (the software I run on it is memory hungry and comparable to prime95 running 24/7). With successive bios updates it reduced to an error rate of about once a month. Even reducing speed to 3000 didn't eliminate the errors. Replaced it with Ripjaws 5 3200 and there has only been one unexplained error since.
More recently I have Corsair LPX 3000 working fine at XMP in a MSI Z170A Pro Gaming. Move both CPU and ram into an Asus Z170I Gaming Pro, no boot at XMP, unless I drop the block to 2800. I think we have to remember even if the ram is rated for a high speed, the CPU (and mobo) together might not be up to it. Different manufacturers could vary there.
