doesnt matter where u are, they all pull same wattage.
Any power consumption graph oput there is not just for the specific GPU but its showing TOTAL SYSTEM POWER CONSUMPTION with that GPU.
http://www.anandtech.com/bench/product/1715
Your power consumption will be around 400W
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
The above is absolutely true, but it should be mentioned that just because the system will draw 400 Watts or less doesn't mean you only need a 400 Watt PSU. Power supplies are at their most efficient when they're not constantly run at their peak output, so it would be ideal to have a good-quality PSU around 500 Watts.
I put that there to know how much kWh it is. The price
