Hi all, I have a little problem, I can't tell if the  Corsair H100i 77.0 CFM Liquid CPU Cooler will fit into the  Phanteks Enthoo EVOLV ITX Mini ITX Tower Cas?!?! I've put them both onto a list on pcpartpicker  (http://nz.pcpartpicker.com/list/) It says that, ? Unable to verify the Phanteks Enthoo EVOLV ITX Mini ITX Tower Case has sufficient mounting depth to support the Corsair H100i 77.0 CFM Liquid CPU Cooler 240mm radiator.
By the way don't worry about the incompatible cooler with the motherboard because a mounting piece that is compatible with the H100i Comes with the X99E-ITX. Thanks
https://linustechtips.com/topic/622880-compatibility-issues/
Should fit in no problem. "Radiator size up to 240mm"
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
https://linustechtips.com/topic/622880-compatibility-issues/#findComment-8031186
but it talks about a depth problem? I know it can go up the top or the front but what if it doesn't fit because its to big and hangs down to low? interfering with some piece of the motherboard, it is a mini itx case after all
https://linustechtips.com/topic/622880-compatibility-issues/#findComment-8031197
