31 minutes ago, killer123 said:
Even if I will buy 2 hybrid gtx 1080?
some games will run better and some dont, it all depends on the sli support of the game. If your planning on gaming and you want to absolutely sure that you wont have issues. Then go with the new titan
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/622854-upgrade/#findComment-8031184
Can't say for sure.
We don't know specs of new titan.
But it would be better to run single more powerfull GPU, since SLI will bring quiete a few problems.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/622854-upgrade/#findComment-8031229
