Keep my M8?
Solved by dizmo,
I don't think you'll find something for that price that's worth upgrading. Your phone will blow most things out of the water.
If you want something smaller, I'd save up and pick up a Z3 Compact. They're usually about $200 on eBay from HK.
Pretty much has everything you're looking for. I almost picked one up to use when I travel or go mountain biking.
Unfortunately there aren't many phones that keep a smallish form factor. The norm seems to be approaching Note sizing.
