Thermal Paste Question
Go to solution Solved by MoonlightSylv,
1 minute ago, pokechat8978 said:
I'm aware.
It'll be fine, MX-2 isn't electrically conductive.
5 minutes ago, pokechat8978 said:
I'm going to be replacing the thermal paste on my 260x tomorrow.
I have some Arctic MX-2 laying around and I was wondering if it's alright for me to use that.
I'm not familure with that particular paste, but sure it will be good for you.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/622680-thermal-paste-question/#findComment-8029323
