Good morning (at least here in Berlin, Germany :))
I need help making a decision. The options are as follows:
upgrade
Mobi to Gigabyte Gaming G1
CPU to 6700k
Ram to 16gb (or 32?) corsair dominator ddr4-3600
GPU to Gigabyte 1080 g1 Gaming (or xtreme Gaming)
problem here is, my display is rather old (LG W2452TX) and can't take advantage of die new graphics power.
Second option is to upgrade to the new GPU and get an Acer Predator x34a.
This woul'd bring better graphics, question is: is my old system capable of handling this oder not.
my actual system: http://www.sysprofile.de/id173381
another question (and the last i promise): what gpu. I want to watercool the system. I could now get the g1 gaming, as there is alteady an waterbkock from EKWB or i get the xtreme Gaming witch has more power, but there is actual no block.
Maybe the Customer Support at EKWB can help, will mail them :D
thx for the replies
Jan
https://linustechtips.com/topic/622235-what-to-upgrade-first/
OK, Are the options all you are going to upgrade or is that what you have to choose from?
Based on my interpretation of your question (which might be wrong)
1. i7 6700k needs an LGA 1156 and your current board is LGA 1155.
2. you will need a 6600k minimum to not bottleneck a GTX 1080
3. 16 GB of ram isnt needed unless if you are running cad software or davinci resolve
4. The components listed are kind of dependent on each other so if you upgrade one you will have to upgrade the other- GPU and CPU
Also welcome to LMG forums. :)
German translation if needed (google translate)
OK, sind die Optionen alles, was Sie oder gehen zu aktualisieren ist es das, was Sie von zu wählen?
Auf der Grundlage meiner Interpretation Ihrer Frage (was könnte falsch sein)
1. i7 6700k braucht eine LGA 1156 und die aktuelle Board ist LGA 1155.
2. Sie werden ein 6600k Minimum müssen keine GTX 1080 Engpass
3. 16 GB RAM benötigt isnt, es sei denn, wenn Sie CAD-Software oder DaVinci Resolve laufen
4. Die genannten Komponenten sind so eine Art voneinander abhängig, so, wenn Sie ein Upgrade erhalten Sie die Andere- GPU und CPU-Upgrade müssen
Auch Willkommen zu LMG Foren.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/622235-what-to-upgrade-first/#findComment-8024623
It's "upgrade the system" (cpu+board+gpu+ram) or gpu+display only. I know, probably I should wait until in can afford the system and the display, but .... :)
I thought 16gb ram would be enough for the future, don't wanted to add sticks :)
No german translation needed, google translate is still horrible :D
https://linustechtips.com/topic/622235-what-to-upgrade-first/#findComment-8024691
