Hey, Im looking forward to building a computer suitable for gaming. Games I will probably play are CS:GO and GTA 5. I Have picked parts and I want to know if this is the best possible for gaming on budget.
 MOBO: ASUS: H170-PRO
 VIDEO CARD: ASUS GeForce GTX 970 "TURBO OC" (im looking for nvidia graphic card because of shadow play n stuff it features)
 CPU: Intel I5 6600K "UNLOCKED"
 CPU COOLER: Cooler Master Hyper 212 Evo
 PSU: Cooler Master "GM Series" 550W
RAM: Kingston PC4-17000 "HyperX Fury" KIT (16384 MB, DDR IV, 2133 MHz)
HDD: Western Digital WD10EZEX "Caviar® Blue™" 1TB
CASE: Corsair Carbide 200R USB 3.0
https://linustechtips.com/topic/621014-building-my-first-pc/
I'd consider getting an SSD (240GB) for your OS, apart from that, I love this built:)
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/621014-building-my-first-pc/#findComment-8011517
1 minute ago, jakckakc said:
Sorry if i sound like a neeewb but what is the point of SSD, apart of its speed. Can it improve performance?
Improves boot speed, can help with certain games that may require access to DLL's if you install games directly onto it (larger SDD's) can significantly improve load times
https://linustechtips.com/topic/621014-building-my-first-pc/#findComment-8011549
6 minutes ago, jakckakc said:
Is H Motherboard not overclockable?
Not really...
If you're planning to overclock well, go with a 'Z' motherboard.
If you're not planning to overclock, you can easily get away with going down to an H150, or even an H110 to better suit your budget.
https://linustechtips.com/topic/621014-building-my-first-pc/#findComment-8011587
16 minutes ago, Cracklingice said:
No it is not.  Only the Z170 chipset.
Asrock Hyper series goes around the OC limit from intel. They use a special chip to do that.
It basicly adds overclocking options to the H chipsets and allows you to overclock non K cpus as well.
https://linustechtips.com/topic/621014-building-my-first-pc/#findComment-8011634
