Planning to get WATER COOLER for my CPU
Suggestions :)
Budget 6K
P.S my PSU is 750 W and GPU's recommended PSU is also 750
So do I have to get a new PSU?
My SPECS
Processor - Intel i7 4770K 3.5GHZ
GPU - Sapphire ATI Radeon R9 290 TRI-X OC 4GB
RAM - Crossair VENGENCE 8GB
Motherboard - ASUS Z-87 K
PSU - Crossair RM 750W
https://linustechtips.com/topic/620756-cpu-cooler/
Suggestions :)
Budget 6K
My SPECS
Should look at the EKWB Predator 240 kit, Excellent kit. You should be fine with your PSU as well.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008827
You're fine with the psu you have, unless it's really really stretchy. We need more info to recommend a cooler. We'll need to know what case you have / what mounting options your case has.
No point in recommending a cooler that won't fit.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008830
Well I'm looking forward to buy CoolerMaster SEIDON 120V
and the CASE I'm having is of some SAMA company, i don't know it's model number :/
sry
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008852
Good point, I assumed he had a case that would support 240mm rad since he had a decent system spec.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008853
sry
What fan mounts does it have? Size, position, etc.
My rig:
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008859
Yeah I never assume, and I don't like recommending something unless I'm reasonably sure of compatibility/fit
My rig:
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008876
I normally don't either, slip up on my part :/
Community Standards
"Beast Mode"
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8008879
sry
Also, a single slot rad, even thick ones aren't worth the cost. A comparably priced air cooler would work as well or better in most cases. Hell even the cheap 212 evo works about as good as the 120v
http://www.pcper.com/reviews/Cases-and-Cooling/Cooler-Master-Seidon-120V-Liquid-CPU-Cooler-Review/Test-Setup-and-Temperat
My rig:
https://linustechtips.com/topic/620756-cpu-cooler/#findComment-8009205
