Running dual monitors from different sources
Solved by Nonco,
2 minutes ago, MilkJugg24 said:Unless the connections are coming from the graphics card, it's not using it at all. The card is literally doing nothing.
The display is currently running off the Quadro like ive said since the start.
I managed to make both ports fit into the quadro now so I guess problem is solved. However I had to grind down a part of a DVI adapter lmao
Featured Topics
tommmie20000 ·
Posted in Audio0 -
INotPablo ·
Posted in Cases and Mods0 -
Pove ·
Posted in Power Supplies5 -
Knugen1015 ·
Posted in Windows0 -
1
2
1
10
