Okay, I have a major problem. I recently bought the RX 480 for testing purposes, and it was working fine until I loaded the GTA 5 benchmark on high settings. My monitors went black, saying there was no video signal, so I took the card out and moved it to my 2nd PCI slot. After running the same benchmark on the same settings, my monitors went black again. Apparently, a lot of other people have experienced the same problem, most of them saying the card takes too much power form the PCI slots. I know AMD is working on a driver to fix this issue, but is there any way to fix this problem now? Thanks
https://linustechtips.com/topic/620119-rx-480-pci-problems/
what motherboard are you using?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/620119-rx-480-pci-problems/#findComment-8002292
Try undervolting
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/620119-rx-480-pci-problems/#findComment-8002318
1 minute ago, Swaggermon said:
It works fine until I start playing a graphically demanding game.
I'd check to see if the voltage and clocks are set to default in the Radeon Settings menu.
I'd try lowering the clock speed a little along with the voltage just a tad. Just to see if you can get it going for a while.
https://linustechtips.com/topic/620119-rx-480-pci-problems/#findComment-8002319
sort of a different question than what is asked here.... but does AMD have a return policy or refund policy or something in place for these issues? its plaguing a lot of people and I'm wondering if they have steps in place to reimburse people they sold their defective cards to. Rather than just a "wait and maybe we can fix it"
As far as your situation goes, you can undervolt (since the reason its crashing is its drawing more power from the PCIE port than your motherboard can handle). You can also (if you have one) use a higher quality motherboard with more power phases/power allocation. Having a motherboard like that has allowed some people to not experience this issue.
https://linustechtips.com/topic/620119-rx-480-pci-problems/#findComment-8002324
Welcome to the forums.
The problem you're facing is indeed what should happen when your motherboard PCI Express slot cannot provide enough power. The computer should shut off.
http://semiaccurate.com/2016/07/01/investigating-thermal-throttling-undervolting-amds-rx-480/
Some solutions you can follow are:
1) Under-volt the card,
2) Power limit the card upto -20%.
Unfortunately some motherboards cannot provide a lot of sustained power through the PCI Express slot. While this is not the first case of cards pulling (in fact a lot) more power from the PCI Express slot, it's probably the first case of a card pulling consistently more from its slot.
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/620119-rx-480-pci-problems/#findComment-8002334
