Spdif port lighting up, but no audio
Roboslash1
Hi,
My laptop has three ports, a microphone, a headphone and a spdif/optical out port. The problem is that the spidif port lights up in red, and when I plug a pair of headphones inside the audio port, I get no sound. How can I fix this? I read a bit on google and most people with this problem are on macbooks where the light is showing from the audio port. Some people say that the solution is to take a toothpick and hit some "switch", but I dont know what I am supposed to look for and I feel uncomfortable doing that.
Im not sure if thats even the correct solution. Thats why I wanted to ask here.
Thanks.
Desktop: Processor - Intel Core i7 5820K   Motherboard - Gigabyte GA-X99-UD3   RAM - Crucial Ballistix Sport 16GB 2400MHz DDR4   GPU - Gigabyte GeForce 980 Ti G1 Gaming 6GB Case - Fractal Design R4 Window   Storage - x1 WD Green 1TB, x1 WD Green 2TB, x1 Samsung 850EVO 120GB, x1 Kingston SSDNow 120GB  PSU - Cooler Master B700 (700W)   Displays - x1 Dell E2214H, x2 Dell 1908FP-BLK   Cooling - Noctua NH-D14 SE2011
Keyboard - Razer Blackwidow Expert 2014   Mouse - Razer Deathaddder 2013   Speakers - Logitech Z906 5.1 OS - Windows 10 Pro   Headphones - Steelseries 9H, Sennheiser Momentum
9 minutes ago, Roboslash1 said:
Hi,
Thanks.
Are you plugging headphones into the SPDIF port? That port is only for toslink optical fibre cables, and won't work with anything else. It's intended for connecting to a surround sound system.
If you aren't getting sound from the headphone jack, are the relevant drivers installed? My old system had a SPDIF connector that blocked the 3.5mm connectors from being used unless I had realtek drivers installed.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
I actually got audio from that port to my headphones, but plugging my headphones into the headphone port gives me no audio :/
Oh, its a combi jack. Are you sure the other jack is for headphones? If you're running windows, have you got the correct drivers installed (e.g. not the windows default audio drivers)
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
Yes the other hack is for headphones. Its labelled on the side. I do have the correct drivers installed and they are from realtek. Will reinstalling maybe help?
There shouldn't be a problem then O.o Google your laptop model no. and see if others are having the same problem as you. Re-installing might help though. Go into your playback devices and see how many audio devices show up.
If you see a separate entry for another headphone socket, try setting it as default.
When you plug devices into your headphone socket, does a pop-up appear asking you what device you plugged in? My headphones don't work until I acknowledge the popup message.
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
  Reveal hidden contents
Thanks for the reply. I reinstalled drivers and everything works perfectly now. However, the spdif port still lights up, regardless if the headphones are in or not. Is this normal?
That's completely normal. There might be an option to turn it off somewhere, but it's nothing to worry about.
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
Alright. Thanks a bunch with the detailed replies. Nice to see helpful people around like you ;)
