Help with my build
Solved by Herman Mcpootis,
3 minutes ago, AceTaker said:I need a new case since the I/O shield wont come out
i see, then get this(reuse your ddr3, or you can resell it, mobo/cpu and case to get ddr4)
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: ECS H110M-C3D (1.0) Micro ATX LGA1151 Motherboard ($50.98 @ Newegg)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory ($16.88 @ OutletPC)
Case: Rosewill SRM-01 MicroATX Mini Tower Case ($19.99 @ Newegg)
Total: $198.84
Generated by PCPartPicker 2016-07-02 09:54 EDT-0400
