Different window style and and programs opening weird
*Windows 7* yeah so i just put this pc together and in my last post i talked about how it was not going as well as i had hoped. I reinstalled windows and now im having these weird issues that i did'nt have before. I went to change my color scheme to transparent and the menu looks different now (along with not being able to make the bars transparent) whenever i pull one window over another it either makes a trail or turns the one behind it white, when i make a window full screen the top bar goes first then the rest of the window, and the X minimize bar looks different. I'm not exactly sure how to fix these to the way they were before, any input would help, thanks.
https://gyazo.com/daadc8ec5fccd80905de90e269d907c2
Driver related.  Please look at the link in my signature for installing Windows.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
9 minutes ago, Ahov said:
will i need to reinstall this all again?
Well...  If you did it wrong you did it wrong.  I probably would install Windows in a more proper fashion.
3 minutes ago, Ahov said:
i mean i used the disk and everything i just dont understand how i got it wrong
There are no disk involved in the installation of Windows.
then what does this disk that says windows 7 home premium do?
edit: i see it says backup and recovery now
I mean, I spent 4 hours on a guide to installing Windows.  And I don't ever suggest using a disc of any kind.
