I'm building a new computer and really really needed to know which of these graphics card will have more fps and smooth gameplay.
GIGABYTE GTX 680 WINDFORCE 3x : I really liked this one because it has 3 fans on it and looks like it would be really good to oc it.
MSI GTX 680 TWIN FROZR:I've seen FANTASTIC reviews about this card 5/5 scores on Amazon and looked epic.
GTX 680 ASUS DIRECTCU II TOP edition.
Also is a i7-3770k 3.4 good for rendering videos quick? Or should i go with a 3.5 one?
https://linustechtips.com/topic/6193-help-me-decide-o/
I would suggest you go for either the MSi TwinFrozr 680 or the Asus card. I personally prefer the aesthetics of the MSI card, so that get's my vote; however, the Asus CUII is an equal, and perhaps better, in terms of performance. As above in regards to the 3770, i would suggest you go with 3770K (3.5ghz) just because of the added ability to overclock. .1GHZ will make no noticeable difference to rendering times, so the -K enables overclocking which is something nice to have, even if you don't utilise it at first.
https://linustechtips.com/topic/6193-help-me-decide-o/#findComment-68265
BTW what psu do you think the ASUS GTX 680 DIRECTCU II TOP edition would need??
550 Watt + would be OK.
I recommend over 600W if you are going to be overclocking both the CPU and GPU.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/6193-help-me-decide-o/#findComment-68481
