So I'm planning my very first build and just want some feedback. Any feedback is welcome and I'm open to anything that is reasonable. :)
PCPartPicker part list: http://uk.pcpartpicker.com/list/rMcvVY
Price breakdown by merchant: http://uk.pcpartpicker.com/list/rMcvVY/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£170.99 @ Ebuyer)
CPU Cooler: Cooler Master Hyper TX3 Evo 43.1 CFM CPU Cooler  (£15.99 @ Ebuyer)
Motherboard: MSI H170 Gaming M3 ATX LGA1151 Motherboard  (£100.22 @ Ebuyer)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory  (£34.98 @ Ebuyer)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£79.98 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.99 @ Ebuyer)
Video Card: Sapphire Radeon RX 480 4GB Video Card
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  (£72.99 @ Ebuyer)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  (£35.49 @ Ebuyer)
Total: £552.63
Generated by PCPartPicker 2016-06-30 23:12 BST+0100
(Total price isn't the final as there isn't a price for video card.)
https://linustechtips.com/topic/618962-first-build/
Total: £552.63
Nice first build!
When life gives you drugs you sell them for a living.
https://linustechtips.com/topic/618962-first-build/#findComment-7989752
Total: £552.63
I would wait a while and get one of the custom rx 480's, but it's up to you
https://linustechtips.com/topic/618962-first-build/#findComment-7989759
The 8GB is very appealing but, I don't know if I will be able to fork out another £20-£40. I would like it though.
You can dry dropping the cpu cooler and get it later since you cant oc (not sure on intel) and maybe consider little bit cheaper case
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/618962-first-build/#findComment-7989860
Dump the tx3 to get a better psu, that one isn't very good for a gaming pc. Xfx ts 430/550w would do better.
https://linustechtips.com/topic/618962-first-build/#findComment-7989878
1 minute ago, AntZz3011 said:
Umm im not sure what you mean??
He means get psu with better build quality. its not a must since ive used one cheap psu for 2,5 years. I would rather get the 8gb vram card to get little bit of future proof
https://linustechtips.com/topic/618962-first-build/#findComment-7989923
Well i picked that PSU in particular because it's been told to me by many people that it's a really good PSU for its price. In terms of future proofing, I can understand that but for someone like me who sticks to only a few titles, I felt that 4GB was enough. Please correct me if I'm wrong. and also I believe that the i5 processors do not come with stock coolers hence why i went with the tx3.
https://linustechtips.com/topic/618962-first-build/#findComment-7989948
Only the 'k' versions don't come with a cooler. The i5 6500 has a stock intel cooler.
https://linustechtips.com/topic/618962-first-build/#findComment-7990010
