Hello, I have a P7P55D motherboard and I just bought a hyperx savage 240gb ssd. I want to install OS on it but there is a problem saying that the bios cannot support the storage device. Is there maybe a way to install it when I am running windows from another drive and then boot from it?
https://linustechtips.com/topic/618957-problems-with-ssd/
update bios
https://linustechtips.com/topic/618957-problems-with-ssd/#findComment-7989754
try using another stat port or update the bios.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/618957-problems-with-ssd/#findComment-7989755
Being an SSD it shouldn't matter as it is a standard SATA device. The only time it should make a difference is if it is an NVMe SSD.
Check your SATA controller mode, is it set to IDE (Legacy) or AHCI.
https://linustechtips.com/topic/618957-problems-with-ssd/#findComment-7990376
