I have a 2015 macbook pro retina 13" and it has been fine but sometimes when I shut it down a few seconds later it randomly turns back on again. Sometimes the track pad won't work and sometimes it will. And now when it did it it came up with a load of text on the top left corner of the screen and froze for a few seconds. Then it restarted and said it had crashed. After it restarted it shut down fine.
How can I fix this?
Thanks.
PC Specs:
Core I5 4690K CPU
Gigabyte GTX 960 windforce 4GB GDDR5 GPU
Corsair 100R case
Seasonic 620W S12-II PSU
Kingston SSDNow 120GB SSD
Toshiba 1TB HDD
Asrock H97 Pro4 motherboard
8GB panram DDR3 1600 RAM
Windows 10 home 64 bit
https://linustechtips.com/topic/618914-macbook-pro-wired-problem/
have you tried reinstalling the OS?
No. How do I do that?
PC Specs:
Core I5 4690K CPU
Corsair 100R case
Toshiba 1TB HDD
http://mashable.com/2015/10/01/clean-install-os-x-el-capitan/#8MbcA0hzIEq8
