I've been having trouble with my new computer. When I boot it up the disk will run at 90 - 100% for the first 10ish minutes before crawling back down to acceptable levels for the rest of the session. Not only that, but when I wake it from sleep the disk will run at 100% indefinitely, and I'm forced to reboot. When the disk is running at boot up, or after I wake it, the numbers in task manager don't add up, with it only reporting current usage of around 2 Mbps. I've already tried disabling a whole slew of windows features that people say cause the problem, as well as updating a few drivers and flashing my bios. I'm sick of this problem and I just want it to stop, so please help.
System specs:
Thanks.
Update: I have verified that no updates are taking place, and my system is not set to run chkdsk on boot up. Needless to say I would like to get this wrapped up a soon as possible, I ran chkdsk earlier and noticed that my disk grew 8kb of bad sector space because of the constant overusage. Please halp :P.
https://linustechtips.com/topic/618791-hard-drive-100-usage-problem/
System specs:
Thanks.
Its probably caching the hdd in ram. Don't worry about it. Its making your computer faster.
Google.com is such a nice website...
http://www.thewindowsclub.com/check-disk-runs-at-every-startup-windows
"The Check Disk Utility or Chkdsk.exe in Windows 10/8/7 and Windows Vista is used to check for errors in the disk media and in the file system. If you face problems ranging from blue screens to inability to open, save files or folders, you should run chkdsk.exe. Check Disk can run automatically, in the case of an abrupt shutdown or if it finds the file system to be ‘dirty’. There may be times, when you may find that this Check Disk Utility runs automatically every times your Windows starts. You may have scheduled its run, or your Windows may have decided to schedule its run. But instead of running just once, it continues to run every time your Windows computer boots."
