Okay guys, we need your help because ASUS isn't helping.
Intel i7 - 6850K
Deepcool Captain 240
ASUS X99 ROG STRIX AURA LED MB
8 STICKS - CORSAIR DDR4 4GB BLUE 3000MHz - Vengeance
CORSAIR HX850i
X31 RGB Edition Case
GTX 970 SSC EDITION
256GB PCIe SSD - 850 PRO
480GB SSD PNY CS1111
960GB SSD SanDisk Ultra II
We get post code 13, then 60, then either 53, or spam after 60, I'll link a video down below as soon as it's uploaded.
CPU: Intel Core i7-6700HQ (Undervolted -0.150mv)
GPU: NVIDIA GeForce GTX 1070
RAM: 16GB DDR4
MOBO: Alienware 17 R4
Storage (Boot): Samsung 960 EVO 250GB (M.2 NVME)
Storage (Games): Samsung 850 EVO 1TB (SATA III)
Storage (Backups): Sandisk X400 128GB (M.2 SATA)
Display: HP Omen 25” 144Hz 1080p
https://linustechtips.com/topic/618532-post-code-errors-please-help/
did you look in your manual it should say.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
53 says invalid memory type, or invalid memory speed, so the computer, or motherboard power button don't work, but if you plug it in, it turns on, fans spin, LEDs on, but turns off after a second, and won't turn back on unless unplugging. So the motherboard support up to 3400mhz, and mine is 3000, but it's only in OC, and the max supported before overclock is 2133, but I can't get to the bios because it doesn't turn on. The other post codes seem normal.
RAM: 16GB DDR4
use the mem ok button if it is on that board
What will that do?
RAM: 16GB DDR4
20 minutes ago, ClaudioBravo said:
What will that do?
sorry will change the memory speed to something slow to allow it to post
The motherboard is no posting, we plug it in, the fans spin, CPU light is red, then the RAM light is orange, then back to the CPU, and the back to the RAM, meanwhile, posting is going from 13-14, to 60, to 14, to 60, to 60 spamish. The reset button does nothing, the power button does nothing, I am going to upload the video and send a link.
RAM: 16GB DDR4
that mem ok button will help it post
RAM: 16GB DDR4
The video needs to process and the memory ok button doesn't do anything
RAM: 16GB DDR4
  • 1 month later...
Requesting Deletion Of This Thread
RAM: 16GB DDR4
